Originally Posted by
curtisbyrne
well after trying everything still no spark.figured i take another look at the coil and remove it,unfastens the bolts and the coil is split on one side. it was not split when bought by the way. peed off to the max
that is perfectly normal. all those steel plates are just stacked. once you tighten the bolt, they bend slightly and don't stay together anymore. when installed, the bolt holds everything together.
