Predator 22hp Twin install in an Argo Vanguard II. Need Clutch recommendations
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Predator 22hp Twin install in an Argo Vanguard II. Need Clutch recommendations
  1. #11
    Hi AWD, I am very excited to get this motor into my ARGO....it has almost double the HP of the original (B&S 16HP) and it's an EFI!!! My biggest concerns are getting the mounting plate and motor positioned right and getting the exhaust sorted out. Any tips/advice out there would be VERY much appreciated!!!
  2. #12
    Quote Originally Posted by Rickb View Post
    Thanks for the input on the clutch Vanguard.....I was ready to pull the trigger and buy the comet - I thought the specs matched the ARGO belt width of 1-3/16 belt.....there are many comet 94C options (see link below) - I was looking at Part#: 219739A.......would this one not be compatible with the existing driven clutch?
    http://www.mfgsupply.com/snowmobile/...wcomet94c.html
    Argo uses a belt that is 1.469 inches top width. The clutch you are using has a max width of 1 3/16". so the driven clutch will be set up for the factory belt. That clutch will work if you change the driven clutch to match the driver clutch and can find a belt that is the proper length.
  3. #13
    You are right....thanks....I will not order that clutch.....I want to keep the driven clutch, so I will try and find a driver that works.....looks like my best bet will be the conquest driver.
  4. #14
    That's what I learned. I ordered the factory Argo clutch as I'm told it's good with the higher hp motors as well
  5. #15
    OK - I will run the factory clutch from my 1998 Vanguard.....does anyone know what the offset between the driver and driven should be??? I forgot to measure the factory clutch offset when I took the 16HP B&S out of the ARGO.
+ Reply to Thread
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
