Lots of small engines use a fuel shutoff solenoid. They typically take 12 volts to run thru one wire and ground thru the body. Not sure why that would burn up with power, but it definately will stop fuel and therefore the engine. Typically they are screwed into the bottom of the carb, are cylindrical and have one wire. It is not necessary, but is a safety. Some can be bypassed but will have to see yours to see if thats possible.
Jason
2015 Argo frontier EFI Camo. 4000lb vortex winch with synthetic rope. 3.3 trans.
~1998 Max IV (SN 14428) on 26" TRU Power tires, winch with synthetic rope, rear seat moved back 5 inches, flip top rear seat with storage underneath, 55 lb thrust trolling motor, #24 marine Battery and a bilge pump just in case.-sold
