Being from down under (you) I'm not into the litre thing, how many ounces is that about 8? If so you have internal issues, did you try a compression check since you didn't do the leak down test?
Just FYI, you can probably find a new piston and ring set and head gasket, but valves are long gone unless you find someone up there with some on the shelf.
