I noticed a lot of wobble on my front right tire and it turns out the front right inner bearing basically exploded and created a lot of play.
I am replacing the outer bearing at the same time, but need some help figuring out how to get the inner bearing back in the flange. Is it suppose to just slide in, or does the flange need to be removed so it is pressed in? It looks like the flange was dinged up too... do you think it needs to be replaced?
Can anyone confirm if the setscrews on the bearing go on the sprocket side, or engine side.
remove 4 nuts and bolts,put new bearings in new flanges (buy new ones those are no good now) and apply grease to the lip and push flanges together and put bolts through and install nuts...that easy.but you need to remove the 4 nuts to put the bearing on!
