+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 13
Thread: Tranny Rebuild
  1. mike bar is offline Master Mudder mike bar is on a distinguished road
    Join Date
    Dec 2008
    Location
    Harvey New Brunswick Canada
    Posts
    136
    Tranny Rebuild
    Hey guys, Haven't posted for a while, but have been viewing. I have the slowest project ever i'm sure!! I need some advice on tearing into a argo tranny without a catastrophy. I want to do it myself but am nervous I botch it. I was told by my argo guy that it needs some spacers(slipping out of low gear and reverse when i give it to much gas).I have the diagram and there appears to be ALOT OF SMALL PARTS TO FALL OUT WHEN OPENING.Took my jack shaft to get rebuilt for new bearing as well. New bearings all around. thanks for now,
    Mike.
  2. eightwheeler is offline Master Mudder eightwheeler is on a distinguished road
    Join Date
    May 2008
    Location
    Ontario,Canada
    Posts
    214
    Don't be afraid, there really is nothin in there that you could mess up, actually i was really surprised how simple they are when i opened mine up. Open it up and have alook at the gears for wear
    "I hate 2 strokes"- No offense
    "Argo 8x8's only" type of guy
  3. m350 is offline Master Mudder m350 is on a distinguished road
    Join Date
    Feb 2008
    Posts
    175
    When we pulled my tranny apart,,,the cover came off mean,,,,all the bolts were out,,,but there is a shaft about 1/2" in Diameter, that sticks through the cover,,,it was a bear to get it off the small shaft,,,,finally whorked it off,,,gears all looked good,,,then we found the bad Idler shaft in the diff..replaced all bearing in it too,,,like 10 bearings in there I recall.
  4. mike bar is offline Master Mudder mike bar is on a distinguished road
    Join Date
    Dec 2008
    Location
    Posts
    136
    Thanks guys, argo dealer says he can fix for around $200 for 2 hrs. work plus parts. do you think this is reasonable?
  5. spits is offline Sophomore Slider spits is on a distinguished road
    Join Date
    Feb 2009
    Posts
    87
    $200.00 Plus parts????? Ouch. I must be out of touch with reality. If $100.00 bucks an hour is the rate for an Argo dealer I'm going to set up my business a little faster. Seems a tad steep to me but I do all my own work. It may be cheap in the end if you happen to mess it up though. I guess it would depend on experience and how brave you may be.
  6. spits is offline Sophomore Slider spits is on a distinguished road
    Join Date
    Feb 2009
    Posts
    87
    I should have added in my last post , like eightwheeler said they are a very simple gearbox. If you do run into trouble ask some questions or if it comes down to it, horrors on horrors, you could take it to the dealer. But that is a nasty thought.
  7. mike bar is offline Master Mudder mike bar is on a distinguished road
    Join Date
    Dec 2008
    Location
    Posts
    136
    Sorry spits,I probably didn't word that right. I meant $200 total. He said 35/hr plus parts. thanks for info.
  8. spits is offline Sophomore Slider spits is on a distinguished road
    Join Date
    Feb 2009
    Posts
    87
    $70.00 in labour is pretty cheap. You would have to pay for the parts anyway. I would do the work myself but then I've also worked on that kind of stuff for 30 odd years off and on. working with aluminum can be tricky sometimes. If you do the work, just take your time and watch as things come apart. If the case won't split because the bearings are tight in the case , use a heat gun(paint stripper) to heat the case around the bearing. the aluminum heats faster than the bearing, expanding enough to let the bearing come out. I had mine apart to check it out and replace the bearings and seals. I have one speed ahead and one reverse so I am not familiar with the two speed.
  9. InTimadator is offline Sophomore Slider InTimadator is on a distinguished road
    Join Date
    Feb 2009
    Location
    Estey's Bridge, New Brunswick
    Posts
    57
    Tranny
    Mike,
    Since I am from Fredericton which dealer gave you the quote ? I'm rebuilding an Argo and am dealing with Brown's they seem OK. Tim
  10. mike bar is offline Master Mudder mike bar is on a distinguished road
    Join Date
    Dec 2008
    Location
    Posts
    136
    Thanks again spits. I've thought about this long enough now.I can do a job on the side working with wood and know what I'm doing, rather than working with something i'm not familiar with and possibly breaking it. The labour would be the same and all i would be paying for would be parts.Hope that made sense.
    To answer your question Tim,I have been going to luch in tracy.who is browns?
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
