New (to me) Argo up and running
Well, I went and picked it up, the thing was Massively rusty under the floorboards. Looked like it was left outside with the plugs in for some time. The engine would not run worth a crap (would only run if half choked), the gas in the tank was brown, the left side Idler sprocket was so far out of alignment that half the teeth were gone from the Drive sprocket.The valves needed to be set, plugs changed, winch cable was a rats nest. Tracks were frozen lumps burried in a snowbank, ect, ect. It's not as new as I was told, I have it pegged as a '97.
The good thing, as best I can tell, is that it was mostly rebuilt just prior to it being left out to the ellements. Bearings are all solid, clutches and brake disks pulled off the shafts with ease (fresh Anti-Sieze on shafts). It came with a new carb, fuel pump, and fuel lines still in the box. Chains are rusty, but not stretched (new). Also got a 100ft roll of 2-50 chain. Chain tensioners and wear pads apear new as well. The guy also had MOST of a set of "Supertracks" kicking around, and told me that I could have those with the Argo as well.
I have put a few hours into it, and so far I have :
Serviced everything.
Changed the fuel, pump, filter and fuel lines.
Changed SP's and set valves
Changed the carb and springs
Changed out the Brake Disks and the Idler Chains
Rebuilt and modified the Clutches
Installed the tracks (Weird Rubber Tracks, must be aftermarket, kind of a flat belt with V shaped treads)
Changed Tappet Cover Gaskets.
Adjusted the brakes
This thing is running fantastic now, better than my other one. Also noteworthy is the lack of noise from the trans, compared to my other Conquest, this one is in "wisper mode"
I can't post pics right now (I'm at work, and keep getting a fail to upload, probably has to do with our firewall). I will get some up later.
One thing I'm a little worried about is what I'm going to be in for when I have to change Axle Bearings and Idler Bearings. Even the nuts and bolts on the bearing carriers are very rusty. Is there a product that any of you guys know of that I can put on the rusted axles, Sprockets, bolts, ect that will.................remove, disolve, eat, vaporize, or just get rid of the rust? I've already tried to move a few of the axle sprockets, and they will not budge.......at all, so I can just imagine what it's going to be like to do the bearings on this thing, when they fail:confused:
