Originally Posted by
AkBillyBow
All, thanks for the help. I am very new to all of this and have not read entirely through the manua....so I need to do that first. I believe I inflated the tires to 7/5/5/6...which seems to be wrong. I am going to pull the tracks, measure the tires and make sure the pressures are correct. Can you tell me which way to install the tires after I measure them? One last question, what RPM are you guys seeing at full throttle and top speed. I believe I was around 3100 RPM. If I am low, maybe I need to check my throttle cable for slack/adjustment. I will also do a cal on the speedo.
Thanks again for all of the help!!!
AkBillyBow
