Hey guys, just found this on ebay. https://www.ebay.ca/itm/401175559348
I'm curious, will this led bulb fit in the headlight bulb socket on my 93 magnum ? If so, thats a easy fix to my bad lighting, plus likely to save a little battery power too ?
Printable View
b
that bulb will not work however another might but the way it is on mine and yours is a light with a little wire coming out of it that connects to a spade terminal.
H3 30W CREE LED Light Bulbs Headlight Bulb for Polaris ATV 4030056 Pack of 2 | eBay
i may consider this too kris.this one will fit im 95 percent sure
What about these? Think they would work? If so it's pretty cheap for the pair.
https://www.ebay.ca/itm/282149355672
no they will not work.the ones i have posted are the exact ones. and cheaper go with them. i just put two new halogen ones in so i will try to run those out first then get the leds.
will be a while i guess
I bought these ones https://www.ebay.ca/itm/112048944128
Hopefully they will work, they look the same as my bulb. They were the cheapest ones I could find on eBay.ca....
$10. +free shipping ... So even if they don't work whats $10. ? It'll take about a month before they get here from China. That's the average turn around anyway. If they work, I will try to remember to only change one at first and post a nighttime picture of the difference between the old and the new.
yep they will work,might be too long tho just a thought.
Not bad, only took a few weeks to get delivered ! I know its daylight when i took the pic, but you can still see a big difference between the new led bulb on the left & the original on the right... for $10. It's brighter and they use less power !
Attachment 15474
i see an alcoholic beverage lol
