1 Attachment(s)
2011 750HDi Inner Bearing/Flange for front Axle
I noticed a lot of wobble on my front right tire and it turns out the front right inner bearing basically exploded and created a lot of play.
I am replacing the outer bearing at the same time, but need some help figuring out how to get the inner bearing back in the flange. Is it suppose to just slide in, or does the flange need to be removed so it is pressed in? It looks like the flange was dinged up too... do you think it needs to be replaced?
Can anyone confirm if the setscrews on the bearing go on the sprocket side, or engine side.
Any help would be greatly appreciated!Attachment 16879
