drive adjustments? ??
I am new to argos, when I am going straight on flat grpund, well trying to go straight. My argo keeps drifting left pretty bad and ya constantly have to make corrections to the right. Also is there a break adjustment for the braking or is it just pads? Just seems like the rig HR side must be turning faster or something. Please advise. Thanks
90%of the time tracking to one side is tire pressure or size difference from one side to the other. First do you have tracks on this vehicle? Even with just tires I would recommend removing all the tires and air up to 5 psi. Measure circumference of each tire, I prefer a fabric tape measure. You may have one or several tires that have been overinflated and may be as much as 5" larger. This is usually the cause of one side traveling faster is large tires or uneven pressure. You could possibly have a craving brake or mechanical problem on the slow side. Most of the time it's tires, and can be cuffed by adjusting air pressure.
