Unit was purchased used in the spring, I put ~60hrs on it this year already(310hrs total). So many places to see, so little time
Issue is Radiator plugging with Fines/Tamarack needles, have to blow it out from Fan side after every use and then Shopvac Air intake housing. Its not uncommon to have to stop often to clean leaves off exterior screen. There are very few "groomed trails" where we Hunt Moose and Elk, just the way I like it. Keeps the Quad access down.
Question, has anyone been running a pre screen before Radiator? I realize it can possibly cause air flow restriction, but I see a possible benefit with ease of cleaning fines before its in Radiator, cleaning exterior of rad just isn't enough sometimes.
Unit is not overheating, just running hotter then normal under load. I typically see 3 bars under normal conditions, 4 bars Pulling Moose, I get belt slipping and hand brake fade off. I will flush brake with DOT5 if I can find any. Feet get pretty warm.
We pulled a small Bull Moose out this morning, -2C last night so not warm, no belt slipping but hand brake fades. No need for a Heater :)
Looking at install hood fan, but see it more as a bandaid
Ever since I bought 2011 750HDI, seems everyone in town calls for help draggin moose/elk out of the bush. Setup to handle pretty much anything, Argos make it so much easier. I actually enjoy doing it
