How fast will it really go??
Quote:
Originally Posted by
Canadian_Zuk
3100 RPM is way too low to fully shift out your clutches. The governors are adjustable and it doesn't take a rocket scientist to set them up properly, you just need a tachometer. Looks like you found your problem anyway, lube the cable and check the linkages at the carb and governor for any binding. On my Kohler the choke tab on the carb can interfer with the throttle if its tweaked up a little.
Thanks Zuk, it sounds so much better coming from a member with your very obvious mechanical skills but I knew that 3100 RPM was way too low for maximum RPM. What you said and maybe like Argo Jim said the throttle "base" could be cracked. By the way,as you know, us Argo Hdi owners don't have chokes. Best wishes my friend:rofl::captain:
