Well it doesn't sound great, what I do hear is driven clutch bushing bad, and either a spacer washer behind clutch is either missing or you need to add 1 more.
You can hear the clutch face wobbling (growl), also at one point I heard the clutch contact the master cylinder or the drive disk bolt ( can't remember what they hit).
Try removing the driven clutch, count how many washers/spacers are behind it on trans. input shaft. Next hold the clutch like a steering wheel at 3 and 9 and alternately squeeze it, if you feel play the bushing needs replacing. Wobble of movable face may also be noticeable in machine while running in neutral at mid to high rpm's and any contact will be apparent for certain at full rpm if that's what I heard.
Also thought I heard something else but may have been the afore mentioned combo.
