questions from a newbie
Results 1 to 10 of 16
Thread: questions from a newbie
    I just bought a 2002 Argo 16 hp. Does anyone know what name this goes by?... Bigfoot possibly?
    It has no gauge for hours, but it looked to be in good shape and it ran well. I changed the oil today Really? you guys go through this every time you change oil? I'd appreciate any shortcuts. I'm assuming that the previous owner didn't like the job either as the oil was filthy.
    Any other things I should be doing to this unit?
    Meadville, Pa
    3,286
    I'm sure there are guys who can ID the machine from that little info, but post a few pictures and someone will respond, usually very quickly too. As for the oil some guys siphon it. some guys seem to try to catch as much as possible from the drain plug and clean the tub afterwords.
    Central NJ
    1,470
    Quote Originally Posted by gravel roads View Post
    Vanguard or Vanguard 2
    http://argotsc.ru/UserFiles/File/cat...rts_Manual.pdf
    statesville, north carolina
    2,604
    this is a simple oil extractor I built a while back. it is a rigid plastic drinking bottle. i drilled a hole and crammed a length of 1/4" fuel line in the hole and sealed it to the bottle with silicone. then put some 1/4 O.D. hose inside the fuel line. the 1/4 OD hose fits down the dipstick tube (all the way to the bottom of the crankcase). i put the shop vac over the opening at the top of the bottle and it draws the oil up and out the dipstick tube
    Ontario-Prince Edward County
    997
    All Bigfoots had a 18 h.p. Briggs. Vanguard 2 had hydraulic brakes. Skunkwork's parts manuals should answer many questions.
    Jul 2009
    Cleveland,Oh.
    1,589
    Gravel Roads, regarding the oil changing, member liflod turned me on to a sweet method. Use heavy duty ziplock bag. Feed(stuff) it down into the framework with to top positioned to catch oil from drain. then remove plug and allow oil to flow down into bag. the fluid will seek its own level in the bag and upon completion of draining zip up the bag and gently remove it. this is not a pull plug and come back latter method but requires attention during. However, I must say that I don't exactly "look forward" to the next oil change but certainly no longer "dread" it. Joe
    Mar 2008
    Rockwell, N.C.
    2,627
    This may be Irrelevan but big foot machines ran 25x12x9 tires. I am not sure if all did the same. But all that i have seen have this tire. The tires may have been changed. Has anyone bought a bigfoot machine (new) with tires other than imentioned?
    Grand Island NY (Buffalo)
    254
    Regarding the oil change. I assume your talking about the engine oil not the transmission. What I did on my Max II was replace the oil plug with a two inch long pipe nipple then attached a 3/8" ball valve with a 1/2" barbed to 3/8" pipe street ell on the outpu of that. Now, when it comes time to change the oil I then slip on a 1/2" flexible plastic hose on to the barbed portion and run it out the lower body drain plug hole to an awaiting container. Wala! To keep the ball valve from opening unexpectantly I safety wire it in the closed position.
    I realize your motor is in the front of the machine which would make the hose path more difficult but perhaps it would still be feasible.
    Mark
    Central NJ
    1,470
    Quote Originally Posted by mark m. View Post
    Mark
    No room for nipples and valves on an argo unless you pull the engine to install it.
    That's easy!
