Mid-80's 8x8 Argo IC...Cork Gaskets?
Results 1 to 3 of 3
Thread: Mid-80's 8x8 Argo IC...Cork Gaskets?
    Sep 2008
    Homer, Alaska
    83
    I have a mid-80's 8x8 Argo IC, and just yanked my bent front axles to replace them with gusseted straight axles. When I yanked off my outer bearing I noticed there were no cork gaskets installed at all. Thinking the previous owner was a slacker, I looked at the parts manual and see there are no gaskets in the Argo explode for this model. Is that possible?
    I was expecting to see, starting from the side of the body; cork, outer bearing inner plate, cork, outer bearing outer plate.
    Regardless, I do have the four gaskets that I bought to do the job, so now I'm wondering whether to just throw them in there or not. Does it matter either way? Oh...and YES...I did replace the seal with a new one.
    Thanks,
    Planter Bob
    May 2008
    Ontario,Canada
    489
    Nice machine Bob, i love those old I/C's, yes they did come that way but i believe Argo put silicone on the carriage bolts, thyen realized it would be just as easy to add a second cork gasket, i have seen some Argo's with just the front flanges double corked and the rest siliconed single cork
    "Argo 8x8's only" type of guy
    "old school Argo expert"
    Sep 2008
    Homer, Alaska
    83
    Thanks for the reply! Yep....I think I'll go body/cork/inner/silicone/outer/bolts (with silicone). That'll do it.
    By the way...if anyone's wondering JUST how bent up my axles were. One had a gap in the middle between a straight edge and the axle of 5/8". Dang!
    This will be a WHOLE new ride!
    Planter Bob
Tags for this Thread
