Argo makes a winch mount that bolts to the frame and just under the upper body. Not sure if it is available for that year though. Other wise you could probably recreate it. Another option is to make a "body band" around the two halves and then fabricate a mount for the winch that will attach/weld to it. If you go that far you might want to incorporate a roof/rollbar and help reinforce it. I have just put pictures up if you need ideas. Mine is probably a little overkill, but I push lots of trees and it better than it breaking off.
