What NOT to do...
Results 1 to 6 of 6
Thread: What NOT to do...
    Nov 2010
    Maine
    44
    What NOT to do...
    Im new to the argo world and just bought a response. I like to drive fast and use machines to its fullest abbility and, I was whipping this thing around my yard having a great time, soo 1) I want to know what NOT to do. What hurts, damages, kills these machines as far as "beating" on them. I always maintain my machines as far as oil changes and greaseing moving parts. 2) what are the major things that go wrong or what to look for going wrong before it breaks? It runs and drives ok, might need a carb clean or its just bad gas im thinking the idle issue is, but that can be another topic if I dont figure it out tomorrow. Any info on what TO do and what NOT to do would be great. thanks!
    Jan 2008
    Vicksburg, Michigan
    3,507
    Well I am not an argo guy but I did learn from a friend whos argo wouldnt charge, that running it around with out a battery is bad if it has the electric fans on the rotors. It overheated the brakes and blew a master cylinder seal. Then a slave cylinder. So make sure your battery is good before you run it. Other then that I think the machines are pretty bullet proof. They are built rugged and can take a beating.
    May 2008
    Putnam, NY
    1,074
    Did We leave out swimming without plugs installed?
    Like you said, maintenance. Grease Bearings, don't let it sit with water in it (Or Under Water ) Check Chains and don't run with whipped chains or you'll have whipped Sprockets too. Engine oil, tranny oil. Really just common sense stuff at least for the most part. Oh, carry a few tools, air pump, chain breaker and a few master links, you'll figure out what YOUR machine needs.
    Attex Super Chief - Sold.
    Nov 2010
    Maine
    44
    What do you mean by whipped chains? and I understand the basic oil and grease but is there anything to look for before something breaks? Bought the machine with 101 hours on it, soo, not sure how things are "supposed" to look. Things to watch out for?
    May 2008
    Putnam, NY
    1,074
    Quote Originally Posted by acharrette View Post
    Worn or Stretched. When your chains wear, they stretch since the pins and bushings wear out. This makes the distance link to link slightly longer. They don't fit the sprockets correctly, ride up on the teeth under load and you get pointy sprockets. At that point you must change both, new chain will get killed by bad sprockets as quick as the other way around.
    I've never had an Argo, but most things are simple enough to tell. For starters, jack the machine up and try to wiggle the wheels/axles. If there is slop in a bearing you'll feel the play. If a bearing fails completely you're stopped at best, or worse damage something else. Too much play in a chain or a maxxed out adjuster is your indicator on needing to replace chain. (Help from Argo guy? I know not all the chains even HAVE adjusters and don't know how much slop is acceptable.) Larry pointed out the need for a good battery. And look for anything that looks "Cobbed" by the Previous owner. Some of these machines get Shade-tree repairs. Others are meticulously maintained.
    Nov 2010
    Maine
    44
    Thanks for the info, im going to check out the chains and stuff today and maybe bring it down the powerlines, and ill let you guys know if anything breaks! and how it goes! haha
