I am looking at picking up my first argo. Just for use aroung the acreage. Seems like i would get more use out of it than a quead. Thing runs good, but needs a secondary clutch. The owner put a clutch in from a conquest in (was told by the dealer it would work) but says the unit powers out. where would i find a clutch for a 79 argo. I am from canada
"The owner put a clutch in from a conquest in (was told by the dealer it would work) but says the unit powers out."
You probably only need a new spring. Put it in neutral and rev the engine to watch it. Does the clutch open and close?
I am from edmonton AB, the unit has a 16hp tecumse (I know that is spelled wrong) the motor runs good and it has a rebuilt gearbox in it. Its not the most "perfect looking" unit but I think it would be a good start into argos and definately be needed around the acreage.
Being from Calgary I have noticed that there is alot more argo sale and serives up there. If you are look for a new used cluch and can not find one up there try Raidtrac in Calgary that guy has everything under the sun for and argo of that year. And yes I would have to agree with the outher guy it sound like you need a new spring/ rebuild on the secondary cluch.
