ARgo Belt Size help
Results 1 to 3 of 3
Thread: ARgo Belt Size help
    Apr 2011
    Ohio
    149
    ARgo Belt Size help
    I have a 1979 argo I swoped the origional TECUMSEH 16 hp engine and put in a brand new Kohler 23 hp which is slightly larger. So I had to move it back about an inch to make matters worse the Argo came with no belt so I dont even have a starting point to go off of. I have looked everywhere for this answer no luck. Should the belt be snug on the pullys, or does it need to be a little lose? I have it measured to a 38 3/8. Any help would be great
    Jun 2010
    Southeast Iowa
    256
    Some pretty good info in this thread...
    http://www.6x6world.com/forums/trans...-question.html
    Apr 2011
    Ohio
    149
    Thanks this helps a little my other issue is what is the proper width of the belt
