Argo axle alignment
Results 1 to 5 of 5
Thread: Argo axle alignment
    Argo axle alignment
    Hello. Lurking for a bit now. I have an Argo TB model, year unknown. I am installing new bearings, and have run into a snag. The PO had the eccentric collars for the outside bearing on the outside of the Argo body. I "outsmarted" him by placing the new ones on the inside, as per the factory parts manual. the axles do not have enough movement for alignment now. They will not meet up with the idlers, or tensioners. What have I done? the outer bearing flanges are heavily sealed at this point and removal to flip the bearing is not looking fun. Is it advisable to turn down the sprocket collar? Or flip em? I do appreciate any help.
    Oct 2008
    Ontario, Canada
    158
    I just finished re-building the bottom end of a 1970s Argo 8x8, it's the exact same set up as yours, you put the bearings in backwards, if you want I can post photos of mine.
    That's what I feared. Thanks for the info. Pictures would be great, to make sure I didn't miss anything else.
    Oct 2008
    Ontario, Canada
    158
    Here are the photos(other photo won't upload ) as promised, this is how the bearing and essintric locking collar should look, as seen from the outside of the tub.
    See, my sprocket hubs extend right to the back of the bearing, leaving about a 1/4inch of space between the back of the bearing and the hub, so there was no way I could have put the bearings in with the collar on the inside(the space simpally just does not permit), I wonder if this was an attempt at an almost "fail safe" method of assemble by dealers and individuals?
    Anyhow, here's the photo:
    Thanks. does the orientation of the inner bearing matter?
