Originally Posted by
mcn5085
i do like it with out a cage, but my main area for riding has a lot of over growth with briers so a cage would help with scratches. any other suggestions to help with my problem????
My HUSTLER Bigfoot has a front bumper. I drilled a 3/8 hole a few inches in from the end and welded a nut over the hole. Then I found some tubing that slides inside the bumper, cut a piece the same length as the bumper, and cut that in half. Built a couple thumb screws from a 3/8 bolt and a steel gusset. under normal riding, the bumper extensions are in, but when I get to briars, I can loosen the thumb screws and slide them out. this added width knocks a pretty wide path of briars down and keeps me from getting beat up too bad
