I oedered the hd up grade all the way around I think I will be getting rid of the axle ext. and outer flanges .anyone got a clue what i should ask for them.i will need to clean them up a bit. but i think they are pretty good any help would be nice
When you say " axle ext " do you mean axle extensions? Or was it a typo and supposed to be axles excetera?
Just curious because you might not need to change the axle bearing extensions or the axles to do the bearing upgrade. If you have an earlier Conquest, then you might WANT to do the extensions, but you don't have to. Earlier Conquests had bearing extensions with the built in " Inner Bearing Carrier " which can be easily machined out to accept the new upgrade. Later Conquests will already match up to the new HDI bearing assemblies.
When I did mine, all I changed was the bearings the inner and outer carriers, and the nuts/bolts. Kept my extensions, axles, ect.
