Actually it was mentioned, you may not have scrolled down far enough:
Quote:
While you're at the hardware store buying sticks, you'll want to pick up some eye protection. A full-face welding helmet is your best bet, but if you're looking at this setup as an emergency-only trail welder and don't want to have to carry anything big with you, you can get away with a set of welding goggles. Just make sure you get a set of goggles with a shield dark enough for welding. You may have to buy the shield separately from the goggles, as most goggles sold in local stores are brazing goggles. These use a much lighter lens than is required for adequate protection while welding. The darker replacement lenses should be located in close proximity to the goggles, just make sure they're marked as replacement welding lenses. While you're there, you might consider a pair of welding gloves, although these are not entirely necessary if you're careful and don't mind a little bit of welding splatter splashing back at you.
Once you've got your batteries, goggles, sticks, and cables, you're ready to weld. Just remove the two batteries from the vehicles, and hook the positive terminal on the first battery to the negative terminal on the second battery. This will hook up the two batteries in series, yielding 24 Volts of power.
Fix it, Welding on the trail - YouTube
and this guy talks about an "air arcing rod" using coat hanger as filler, similar to Tig
Welding with jumper cables,The Brigham Tea co - YouTube
I am of course assuming Argo parts are steel. I have some map gas and solder as well, but for sticking steel together...
Yes, just get the replacement lens for arc welder helmet, you can find a way to hide behind it, lol
yup didn't scroll down. I have tried to repair some aluminum with this stuff but with mixed results.
Dura Fix Aluminum Welding Aluminum Brazing Aluminum Soldering & Repair Rod
