Could any1 please tell me how important it is to tie the winch into the frame on an argo 8x8.
Im building a custom roll bar for it now and was thinking about this. I have a 30" peice of "C" channel on the front of the argo that surrounds the upper nd lower tub seam. it is bolted in 4 spots and ties into the main roll bar up top. if i sandwiched the upper tub with 1/4 " plate and welded the botom of the winch mount plate to the top of the c chanel ,, i wonder if this would hold ?
the c channel has 1 1/4" tubing welded from it to the upper part of the roll bar above the windshield...
ANY THOUGHTS ON THIS ???
My first thought is that you will tear that "C" Channel right off the front of your Argo on the first hard pull. However, I'm not sure I am properly visualizing what you are trying to do. Have you got any pics?
Is your Roll Bar tied into the frame at all, or just bolted to the tub splitline?
I think 30" with 4 bolts is a little on the light side, might want to extend the C Channel around the front sides of the machine to where the windshield brace brackets are and mount with about 10 bolts. I'm just guessing here, all my machines have the brace to the frame.
The c channel is not tied into the frame at all. BUT,,, I do believe i have come to the decision to tie the front into the frame for my own state of mind !!
On a difrent note, , On the "throtle" side of my transmission, is a lil wet, appears to be and smells like gear oil. Any thoughts ?
Seriously though, just pull the Brake Rotor off that side and check the output shaft and the Plug Plates on that side. The output shaft seal and the Plug Plates can be replaced without too much trouble.
