Well got the Argo this evening and had been sitting for about a year and pulled carb off was nasty. Going to see if it will run better tomorrow. Hope to go tear it up tomorrow. Will post some pics if I figure it out.
Should not be any smoke , just at start up. My Kohler 18 has done over 1000 hours and is as good as the day it was put in. Give it a good run before you start to tinker.
Where can I get a chain clip where the chain hooks together. Stopes smoking after I ran it for a while. Does anyone know where I can get a brake hose for the right side. By the way it's a 1988 model
Argo dealer will have the brake hose there not to bad on price either like $15 a pop. I also have an 88 magnum 8x8 and love it, its a great machine and yes the kohler might smoke a touch on cold startup but once you work out the bugs probably be a good idea to flush all fluids and rebuild the carb, replace the fuel filter, and check the brake pads there fairly cheap too and make the machine fun to drive. Also throw some new spark plugs in it too. Im up to 670 hours on mine.
