has anyone used the Argo spray unit?
Just wondering how it performs?
argo spray unit????
Mitchamus is talking about a sprayer for pesticides/insecticides and such.
If you want an ATV sprayer system, I recommend Bowman. Bowman Manufacturing We have one of their 4 wheeler sprayer setups for spraying rice levees, and its held up well for many years.
2010 Chevy Silverado 1500
1974 Honda ATC 70
1986 Honda ATC 250ES Big Red
There is no Z in Diesel!!
thanks for the recommendation Stonewall.
apparently the Argo sprayer is contoured to fit in the Tub, and keeps the centre of gravity low. (it's 140L)
As I bought my Argo particularly for spraying, I think I might have to take a closer look at it.
I ideally I would like an absolute minimum 100L capacity and something that can be used with two lances at the same time.
Initially I will just be doing spot spraying, but may look at adding a boom sprayer to do pasture and my orchard.
here are some more pictures:
(one of the pics has some kind of tool bucket/box also)
a non-genuine broucher I manged to find has this to say about it:
Now you can spray those hard to get places
• This 140lt Spray tank including a utility tray has been specifically designed for Argo
vehicles.
• This spray tank has been designed to carry the majority of fluid as close to the ground as
possible and fits in the rear compartment of either an 8WD or 6WD Argo.
• It will carry up to 140lts* of fluid with the majority low down in the vehicle around axle level.
• It comes with a 100psi “Sure Flow” high pressure pump, and a utility compartment, handy
to carry those extra tools required in a hard days work.
“This is an extremely versatile unit, nice and consistent with
the Argo’s already low roll over”
• It can also be used in an 8x8 Argo in conjunction with the rear compartment internal liner.
• For added vehicle protection this hard plastic internal liner fits into the rear compartment
of any 6x6 or 8x8 Argo ATV. This liner is a useable accessory to lengthen the life of your
already long-life expected Argo.
* When this tank is used in a 6x6 Argo please note: the rear compartment capacity is restricted
to a maximum of 65kgs
