Can you put an Admiarl tranny in a 96 argo
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Can you put an Admiarl tranny in a 96 argo
    Jun 2011
    Spartanburg S.C. Now
    35
    Well yesterday I found out that my 35HP diesel will not fit in the bottom of the tub with the belt driven fan/radiator,,,Just about 3in too long with the clutch on the motor,,,SSSSSSSSSSSSoooooooooooo,I guess I will mount the radiator kinda laying flat atop the t-20 with a 16in pusher electric fan setup,,,I think its gonna look pertty cool,,,
    Nov 2007
    Decatur,In.
    376
    Do motor work you will not be sorry. I drove Rogers Argo and it was like driving my 40 hp. Mudd-Ox and it was just a reworked B&S. Cougar
    Jun 2009
    Montreal, Canada
    471
    Quote Originally Posted by BREEZE View Post
    AAAAAAAAAAAAANNNNNNNNNNNNNNNNDDDDDDDDDDD what is the point to post this in a tread of a guy asking if the new admiral trany can be retrofitted to an ARGO bigfoot 1996 ?
    Jun 2011
    35
    Well Mr Smog,,,The point is as you said(can be retrofitted)what ever one is trying to dream up to build there machine as they want,when you hit a snag with a custom build or change things arround just think more deeply on it and figure out a way to make it work,,,That is my responce.
  5. #15
    Jun 2009
    Montreal, Canada
    471
    Quote Originally Posted by Jacob 6x6 View Post
    I just wanted one cause they say they dont lose power when you are turning but at that price no way just gona stick with what I have
    If it's really the problem you have, try the clutch readjustments :
    http://www.6x6world.com/forums/argo-...tml#post100810
    then you can tweak the governor for a max unloaded rpm of 4000 rpm.
    I have seen a 4000rpm governed engine and it was a lot better than the 3200rpm it had before the tweak.
  6. #16
    Northern BC
    2,990
    Quote Originally Posted by smog View Post
    Do you have a procedure for this smog?
    I would like to try it on my friends argo. He has the high geared Trans, and something like this might help. Also considered bypassing the governor all togeather, but am unsure about reliability if I were to try it.
    Jun 2009
    Montreal, Canada
    471
    The guy just bent the tab holding the governor spring, I will try to take a picture when I see it.
  8. #18
    I cut each end of my gov spring and bent a loop back in it wow the motor came alive but still has not as much power as I would like in the mud
  9. #19
    Jun 2009
    Montreal, Canada
    471
    then do the clutches as per Rock Doctor's instructions
