Axle Trouble
Results 1 to 10 of 13
Thread: Axle Trouble
    Axle Trouble
    Hi Folks I am looking for some advice from anyone with an opinion or experience. I stared to disassemble the right rear axel of my Big Foot to replace the outer bearing, but I didn’t get very far. The inner bearing is seized to the axel making it impossible to remove the axel from the machine. I have tried hammering the end of the axel, using Kano penetrating oil, and a gear/bearing puller (see pic) all to no avail. If anyone has faced this problem before or can suggest some way to get this bearing loose, I would much appreciate the advice Thanks.
    Dec 2011
    Ontario Canada
    672
    Make sure all the set screws are out.
    A.bit of heat on the collar does wonders but don't burn anything.
    Tighten the puller and apply a bit of heat and it should pop.
    Don't get it red hot.the bearing will probably need to be replaced.
    Don't hammer the shaft or it could mushroom and make things worse.
    Dec 2011
    Mississippi
    214
    I'm with bazoo heat it up it should pop off be sure to keep pressure on your puller
    Mitchell my own method requires safety goggles,take a ball pean hammer and bust the bearing by striking it,its hardened and will crack and break off,clear the debris and put the inner race against a piece of steel and whack it,it will crack and come off easy,maybe not for everybody but it works for me every time and takes out some aggression while Iam at it.N.C.T
    Mar 2010
    Oconee County, SC
    823
    I had the exact same problem last night on my Conquest, but is was the #2 axle from the front on the right side. Bearing seized on axle, soaked it with BPBlaster. Attached Harbour Freight Gear/Bearing Puller14 Piece Set and got busy on it. Need to oil the threaded rod and with a wrench slowly tightened it down. Take your time and it will come off. I've used it on my Hustler rebuild when I had several seized bearings. Every time I had to use it it got the bearing off but destroyed it in the process.
    Mar 2010
    innisfil,ontario
    1,430
    +1 on the pb blaster,soak it then leave overnight.hit with hammer next day and bruise shin when it comes flying out.
    Dec 2011
    west coast B.C.
    312
    I have been replacing bearings for years. If you are not wanting to save it and cannot get it off. First make sure the screws are out. Then if it do,s not come off the fastest way is with a hammer long drift punch. One good hit on the outer race and it falls apart. Remove the balls. And you should be able to get the axle out and work on it. Thats is about the fastest way. It will not hurt the axle.
    Or you could fight with a puller I would prefer to be the the drivers seat having fun.
    Dec 2011
    Ontario Canada
    672
    Quote Originally Posted by North Country Tough View Post
    I wrap a rag around it first to contain the shrapnel.
    Dec 2011
    west coast B.C.
    312
    So do I. Because it will fly in all directions
    Jun 2010
    Southeast Iowa
    256
    Quote Originally Posted by Bazoo guy View Post
    Doh, just got done tearing down my attex and never thought of the rag... got ball bearings and chunks all over the shop. Sometimes it the simple things....
