why does my argo make a sreeching noise when going forward and a popping noise when turning, it sounds like its comeing from the chains. how can i fix it. my argo is a 1980 6x6.
Reason: moved post from introduction thread to the proper forum
Be sure to check your inside bearings as well as outside bearings. Make sure they are lubed well. If you jack up the machine and grab each tire and pull up and down, you shouldn't get much movement. If you do you probably have a bad bearing
