rebuild
Results 1 to 2 of 2
Thread: rebuild
    Jan 2014
    Fort Mcmurray Alberta
    3
    rebuild
    I have 2012 750hdi and replacing the lower half. I need help with the holes that are to be drilled out . i have the drill guide buy not sure where to start . I well take any help full advice thank you.
    What I did with the last one I did was use the old body, or the frame, with a piece of cardboard that ran the length then transfer your marks with the holes centered. Using the body stiffeners as guides the holes should transfer easy enough. An angle drill with a short bit could do the small holes if wanted.
