Winch problems just started...
Results 1 to 10 of 14
Thread: Winch problems just started...
    Mar 2016
    Oshawa Ontario Canada
    184
    Ive never had a winch before, so i dont know what is wrong. The winch was working fine, then today i went to turn it on & it just goes "CLICK" , like when I hit the switch it makes a single click noise, which sounds like it's coming from the box that the power wires connect to.. Power and ground run from the battery to this box and then from this box 2 wires run to the winch.
    "I've yet to encounter a problem that cannot be solved with the right mixture of whiskey and weaponry"
    :ME....
    " From my cold dead hands"
    :Charlton Heston...
    Mar 2015
    Pickering, Ontario
    633
    Clean where your main power wires go to the battery. You have a bad connection most likely, if not the contactor is bad.
    just check your winch solenoid(thats that box) unscrew the connections clean them up and put her together!
    Apr 2014
    Ontario
    20
    how old is the winch? what model? are you able to free spool the cable out?
    Mar 2010
    Oconee County, SC
    823
    Is it an older conquest? Mine does that every now and then, check the wires on the back of the winch switch. They have a habit of working lose sometimes.
    he has a 93 magnum,look like the original winch
    Mar 2016
    184
    Yes i can free spool the cable out, not sure the make of the winch, any stickers on it fell off years ago and I painted it black, i tried cleaning up the connections on the winch because they looked dirty, that didn't do it so I guess I'll try the back of the switch and all the connections on the contactor next.. I don't know what else to do after that.
    :ME....
    :Charlton Heston...
    I'm going to assume your contactor is the black box style about the size of a stick of butter, which is nla.
    Do you have either direction?
    Check all connections starting with the fuse to feed the switch and then the switch for power feed and the individual outs, next check the contactor one will be live, one ground and the other two feeds to winch affected by switch for direction. If it is not something simple you may find it is time to update the contactor to a newer style.
    check your circuit breaker
    Mar 2016
    184
    Without having a tester, I'm pretty certain I'm getting power to the contactor because it's making a clicking noise in the contactor so I think it's safe to say power is going to the contactor & I need to find out if power is coming out of the contactor because if it is then it's probably The winch itself right ? Maybe the brushes or something?
    Edit: ArgoJim- yes its the " stick of butter" shape, no it doesnt work in either direction, it just makes a click sound.
    :ME....
    :Charlton Heston...
