You could always go into the back of the head light bucket and pick up your Hot wire there.
Ether Tie into the wire or unhook the stock light and use the stock pig tail to test them out.
It may just take a Spade wire end ?
If you tie into the same wire and leave them hooked up yes. But thy will come on with them all the time.
Or you could just hook them up to the high beam side. You will need to look over your wiring real good to figure it out as I am not there to see what is what ?
Do you have or can you get a wirering diagram ? That would help you out greatly !!
file:///C:/Users/lana/Downloads/2005-2006%20Foreman%20500%20Service%20Manual.pdf
the wiring diagrams are right at the bottom and scroll up a bit. i could not copy a picture sorry.
