Those are the same part numbers I used. The bearings I had had the groove you speak of. (I can't see the pics on my work computer). If I recall correctly the problem we had was they only fit in place one way, and that way the greasing channels did not line up with the ring grooves on the bearing. We then looked at an original argo bearing and while it was identical, the groove was on the opposite side so that it lined up. So make sure your ring grooves can line up with the greasing channels and you should be good to go I'd say. What we did was cut a small channel in each bearing outer race for the grease to go across the outside with a zip disc and tried to align them so that grease would travel across into the bearing. But after assembly several of the bearings still would not take grease.
