1985 argo model HTB6631
Results 1 to 6 of 6
Thread: 1985 argo model HTB6631
    Feb 2011
    grand ledge michigan
    71
    just picked this argo up and info on this model would be great HTB 6631 seems to run and operate very wellargo.jpg
    mid to late 70,s. mechanical brakes,single drive chains with double 50 idlers. roll pins hold sprocket to axles. stock is a 16hp Tecumseh. those tires do not swim when in water but i find them to be good for everything else.
    Feb 2011
    71
    thanks on the title that came with it its a 1985 year?
    Being a htb it is possibly a 85 without checking, htb should have 2-50 drive chains. Only real downfalls of that machine (era) are pinned sprockets, manual brakes and marginal engine make turning that 8wheeler a challenge in tight areas. They do run good, a school bus style fan under the hood will help with brake heat and engine compartment heat both.
    Feb 2011
    71
    it does have the double wide drive chains
    why do i always think the htb and ht have single drive chains lol
