brakes, is there any trick to bleeding the brakes? i think the plungers in my masters are stuck in the applied position, but i want to make sure i'm not missing something before i jump to that conclusion. they won't gravity bleed at all and i can't move any fluid
trany, how do you check the fluid? it has what looks like a dipstick on the top left, but it won't come out. do i need to loosen the nut on the base? also, how do i drain the gear oil, and what is procedure for checking fluid (hot? cold? engine running in neutral?)?
thanks again for the help
The dipstick screws in the top of the tranny. There should be a line to mark the full level on it. There is a magnetic drain plug on the back of the transmission. I put a pan, to catch the fluid, in front of the frame that the transmission is bolted to(side farthest from the engine) and let the fluid run down the frame, underneath the transmission, into the pan.
