Originally Posted by
ve1sar
Hi, If you are going to get into the Argo business I would not buy a Argo older than 1989. the older Argos do not have splined axles. The ones you may be buying have axles that have roll pins that fasten the axle's to the sprocket. Each sprocket has two pins each. These pins break and you lose that wheel for power. You will spend a lot of time fixing the Argo in the woods or towing it out.These roll pins are obsolete if you can get them from the dealer are expensive. You will be in a world of hurt if you try to run them. All I can tell you is to run away from them and don't look back. Hope this info helps. Regards Paul
I would say that depends on how mechanically inclined you are and how much you like to tinker. Roll pins can me replaced with bolts. you may still break some but they are easy to replace in the field. the sprocket tubes are pretty thick on those machines and have tons of meat to broach a keyway into. Mill a mating key in the axle and you would have a pretty robust setup if you also used a bolt.
