Can someone tell me the hottest I should be running before cooling off? Went for a drive today in deep snow and worried most of the time that I was pushing to hard.I have no low range because I'm trying to get a little playtime in before I rebuild the tranny in the spring. My argo dealer tells me it's a couple of tiny brass spacers need replaced on each side of a gear.Back to the temp. I was running about 230 deg. Still had fun though.
I think that is a hard question to ask because of the lack of guages. I do know when the fan broke of of the powermax and it got hot it ran strange and was easy to tell something wasnt right. Hope that helps.
I put a lazer temp reader on a motorcycle engines heads, and in the summer when it seemed like it was getting real hot it was running about 250 degrees in the warmest spot. I don't kwow if that would help.
Thanks guys. As you know I'm new at this, so I only assume that there is a perfect answer for everything.I guess overall I think I'm just looking for a comfort level here.I'm a black or white kinda guy i guess.18 hp 8x8 with tracks and only high range breaking trail in deep snow prob. not the smartest thing to be doing anyway.Buy the way,shouldn't there be vents in the shroud by my knees for the rotor blower for air flow?
oil temp is higher than coolant, the boiling point is also way higher, if you check out the oil temp with most truckers you will have a real good idea what it should be
hope that this helps you
Darin
