I purchased a '98 Conquest from a fellow that used it for accessing his high country cabin. When it got to my house (Thornton CO - elevation 5342ft) it
ran a little rough and wanted to die when hitting the throttle. This is a typical symptom when the carburetor is under jetted or dirty so I started at the carb. Pulled it and found it has jet 108. Looked clean. (I'll still run some seafoam through it just because I have no history with this carb yet.)
For reference:
My use will be at the following locations:
Pollock SD - 1654ft
Rushville NE - 3740ft
I live at Thornton CO - 5342ft
And elk hunting in the mountains can easily get me to 10Kft
So I hit google etc. looking for a jetting chart. None. My dealer tells me that Argo doesn't have one. Not to be detered, I combed through the parts manuals for conquests and compiled the following:
HTML Code:
Kawasaki FD620D-_S12 Jetting information
(Gleaned from parts documents)
PART# : DESC. : SIZE : ALT. : ENGINE VERSION
92063-2219 : JET-MAIN : #108 : 6560 ft. : FS12-KS12
92063-2239 : JET-MAIN : #110 : 3280 ft. : FS12-KS12
92063-2241 : JET-MAIN : #112 : ft. : AS12-MS12
92063-2354 : JET-MAIN : #114 : 3280 ft. : MS12
92063-2491 : JET-MAIN : #116 : ft. : MS12
There does not appear to be engine versions: ES12, IS12, LS12
Jetting for engine versions AS12-KS12
#112 for 0ft and above
#110 for 3280ft and above
#108 for 6560ft and above
Jetting for engine version MS12
#116 for 0ft and above
#114 for 3280ft and above
#112 for 6560ft and above
I confirmed the above with my dealer.
The part number above is the Kawasaki part number. Argo part numbers are something like 92063C and vary depending on the parts chart (grouped by engine versions). You can order these from Kawasaki small engine parts retailer online like
this one or
this one by the Kawasaki number. If I were ordering from an Argo dealer I would let them know the engine version and the jet#.
I will be getting the other two jets for the set. I did consider a dial-a-jet and I'll post another thread to talk about that.
John
