I inspected the spark plug cables, I cannot find anything wrong with them, front or back.
I found and read all this info:
TROUBLESHOOTING IGNITION SYSTEMS | smallengineinformation.com
How To Test & Fix Ignition System Problems | Briggs FAQ
Kawasaki FB460V 12.5 hp Won't Start Weak Spark
Some good info about fouling
https://jdagccc.custhelp.com/app/ans...ng-%28gator%29
I decided I want to test the ignition coil on the rear cylinder. I can't find the kawasaki hand tester for sale, and on a forum someone mentioned its $138 if you can find it. I read on another forum, you can use an ANALOG multimeter on the coils just fine. I ordered an analog multimeter on amazon for $20. So I'll use that to test according to page 122 in the FD620D manual. I can test the front coil to see if my multimeter is giving accurate readings, since it seems like that one is working fine. I'm hoping a bad coil could be the cause, it seems that most other possibilities are much more expensive fixes.
