+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: putting Attex Chief back together
  1. #11
    mustangwagz's Avatar
    mustangwagz is offline 6x6 World Sponsor mustangwagz is on a distinguished road
    Join Date
    Jul 2011
    Location
    Kittanning, PA
    Posts
    590
    Welcome!
  2. #12
    kat266 is offline Sophomore Slider kat266 is on a distinguished road
    Join Date
    Feb 2011
    Posts
    26
    Now guess what I dont have any spark at the plugs. The engine ran great before I took it out 4 months ago. I did wash the engine and I tried to be careful but I know some water and the cleaner called awesome got down inside the motor. I dont know much about this, but the lights work and the starter works fine. Somebody ran a wire from the red wire on the voltage regulator and I touched the wire to the engine mount and it sparked. I am pretty sure I have power in the wiring harness that plugs into the back of the engine. I dont know how to check a coil or if it has fire coming from the points. I connected a ground wire to the engine and that did not help either. I also unplugged the wiring harness and used the pull start and i still did not have a spark. I am not sure if that means anything.
  3. #13
    Join Date
    Feb 2011
    Posts
    26
    Hey got it running the points were dirty and the motor runs good so far !
  4. #14
    jpswift1's Avatar
    jpswift1 is offline 6x6 World Sponsor jpswift1 is on a distinguished road
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    3,627
    Excellent! You'll be very happy with that JLO twin......they're great engines.
  5. #15
    Join Date
    Feb 2011
    Posts
    26
    Yes thanks, I was surprised how fast it runs. I have got to do some adjusting on the shifting levers one side does not turn to easy to the left. It also has alot of play in the lever assembly on the frame. I have got to remove it and fix it. So far so good.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
