+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: putting Attex Chief back together
  1. #1
    kat266 is offline Sophomore Slider kat266 is on a distinguished road
    Join Date
    Feb 2011
    Posts
    26
    I am putting my Attex Thunder Chief back together. I ran into a problem putting the engine a 440 JLO back in. The T-20 has the 2 disk brake set up. The starter is hitting the rubber bushing on the engine mounting plate and its about a half inch from sitting flat on the engine mount. I am new to 6 wheelers and I have taken it completly apart. Everything lines up great to the transmission and it was working when I removed the engine. I spoke with a guy at Richards Relics and he said to maybe cut the rubber bushing in half to make clearance. I dont want to do this because I know it was mounted with a full bushing when I took it apart. Its got to be a simple solution. Thanks for any help
  2. #2
    mustangwagz's Avatar
    mustangwagz is offline 6x6 World Sponsor mustangwagz is on a distinguished road
    Join Date
    Jul 2011
    Location
    Kittanning, PA
    Posts
    590
    Ok..by the starter...the rubber bushing goes Underneath.. (it did on mine anyhow..so if im wrong..someone correct me..) Here's what yo do. You'll have one rubber between the mounting plate and the frame mount, and one Under the frame mount.. Up on the mounting plate it self, (this is what the motor bolts directly to) that square metal plate with the curled edges will mount down DIRECTLY against the mounting plate. Damn i need pictures...i suck at explaining.. lol
  3. #3
    Join Date
    Jul 2011
    Location
    Kittanning, PA
    Posts
    590
    Need a good laugh?..lol...here ya go!!
    Ok..whipped this up real quick with Microsoft paint...trust me...if ya'll have heart problems, i'd not look at it cuz garuantee you'll soil your pantaloons laughing at it..haha but it DOES explain a little bit.. so....BEHOLD...My 16th century Master piece.... (more like 16 second masterpiece...cuz thats about how long it took. lol
    Attachment 7690
  4. #4
    Join Date
    Feb 2011
    Posts
    26
    Okay Thanks I will do this too. I have pics but i cant figure how to put hem on this forum.
  5. #5
    Join Date
    Feb 2011
    Posts
    26
    IMG_20111128_204257.jpg440 engine.jpg440 engine mount problem.jpgHey Thanks alot for the diagram. Its easy to understand, great job !!! This will solve the problem and get me going again.
  6. #6
    Join Date
    Jul 2011
    Location
    Kittanning, PA
    Posts
    590
    Yup..i see the problem! lol
  7. #7
    Join Date
    Feb 2011
    Posts
    26
    I tried putting the rubber grommet on the bottom of the frame, but it was hitting the chain. I left it off after that and I could not use the square washer it was still to high. I just used a flat washer and the starter cleared. I dont know how to make it work. Will only using the one rubber grommet cause any problems with vibration.
    ATTACH
    =CONFIG]7705[/ATTACH]IMG_20111201_135602.jpg
  8. #8
    Join Date
    Jul 2011
    Location
    Kittanning, PA
    Posts
    590
    hmmm...did you flip the square spacer so the tabs we're point Up?
    rubber was hitting the chain? ...hmmm...thats different....i didnt run into that problem.. i may have to investigate this on my machine..
  9. #9
    Join Date
    Feb 2011
    Posts
    26
    No I did not turn the square spacer tabs up. I will try this on monday. The grommett that is hitting the chain is the one that is a litle bit wider than the round ones that go on the bottom of the engine mount. I took pictures when I took it apart, but of course I did not take any of the area under the starter. I just dont remember having a rubber grommett under the frame under the starter when I took it apart. I actually took 2 Attex's Chiefs apart. The other did not have the 400 JLO mounted. It did have the engine mount plate attached. I dont remember it having a rubber grommett under the frame under the starter area either. I know the one with the 440 JLO had a square spacer with tabs under the starter because I remember I could not get to the bolt and the engine had to be removed first. Thanks for your time in helping me. I really appreciate it. I will get it figured out.
  10. #10
    Join Date
    Feb 2011
    Posts
    26
    I got it fixed and put the rubber grommett under the frame.
    Thanks !!
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
