Attex project
+ Reply to Thread
Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 41 to 50 of 62
Thread: Attex project
  1. #41
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    2,968
    I can't tell from the picture Lance, but was the crankcase getting pressurized from a bad head gasket?
  2. #42
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Quote Originally Posted by hydromike View Post
    Sure looks like it's blown, a ton of carbon on there also.
  3. #43
    Join Date
    Jun 2007
    Location
    Pittsburgh PA
    Posts
    1,153
    yes. direct from cylinder to oil return galley. The engine would smoke a little when getting on the gas. I pulled the air cleaner and saw the breather blowing oil right in to the carb. Holiding wide open, I did see a puff of smoke from the gasket area, then I saw it leaking oil.
  4. #44
    Join Date
    Jun 2007
    Location
    Pittsburgh PA
    Posts
    1,153
    1st try at the engine cover using anything I could find in the shop. I like the way it came out. I will clean it up a little bit and find some matching expanded metal for the top. I'm also going to build a luggage rack for it.
  5. #45
    Join Date
    Mar 2008
    Location
    Rockwell, N.C.
    Posts
    2,627
    Looks very nice Lance.
  6. #46
    Join Date
    Jan 2008
    Location
    Vicksburg, Michigan
    Posts
    3,507
    I like it! Nice work! I like both sides but I almost like the diamond holed side better then the square holed mesh.
  7. #47
    Join Date
    May 2009
    Location
    Meadville, Pa
    Posts
    3,286
    I thought it looked good the way it was. The beer errr cargo holder would be a good addition, but mismatched metal on the cover is cool.
  8. #48
    Join Date
    Sep 2013
    Location
    Caldwell, Idaho
    Posts
    1,174
    Did you make your rollbar yet?
  9. #49
    Join Date
    Jun 2007
    Location
    Pittsburgh PA
    Posts
    1,153
    Just moving the camper to the other garage.
  10. #50
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    This is a very nice machine. I like the U-channel pivot mods. I expect I'll be doing this too. Thanks for the pics of this mod.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
