Help ! anyone know if a B&S L block 18 hp Briggs fit into my Attex tub ??
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Help ! anyone know if a B&S L block 18 hp Briggs fit into my Attex tub ??
  1. #1
    Join Date
    Jun 2012
    Location
    north of Reno Nv.
    Posts
    27
    Hello all from Northern Nevada. I feel like I am all alone out here in the west !!
    First I want to compliment the moderator on this site for doing such a great job.
    Also I am always amazed by the amount of knowledge offered here. And to how helpful everyone is.
    I am seeing the light at the end of the tunnel with the rebuild of the Chief. I was going to drop the original JLO back in when a friend offered me a Briggs and Stratton 18 HP
    L block. I would prefer the 4stroke to the JLO. does anyone have any experience with this engine ? and will it fit in my tub ?
    thanks.
    Any one out there in N California or Nevada?. I have some great trail rides out my back door.
  2. #2
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Here's one, Shane Kearney's gallery, looks like if it were mounted lower you may get away with out cutting the engine cover but a very long belt would be needed. Should work in a little truck nice.
    http://www.6x6world.com/gallery/data.../attex_009.JPG
  3. #3
    Join Date
    Jul 2009
    Location
    Cleveland,Oh.
    Posts
    1,589
    Not identical but very similar,here is an 18hp opposed Kohler in my Colt,
    Here it is with the engine bay cover down so,yes,it will fit,just takes a little custom duct work
    Be advised,you will need to change the spring in your secondary clutch if reusing it. Best wishes on your project.
  4. #4
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    OOPS, forgot about Joe's build. If I am wrong and you are talking an 18hp single cylinder ( which I've never seen) it would be much like the Tomahawk with the Tecumseh and should be fine.
  5. #5
    Join Date
    Jun 2007
    Location
    Pittsburgh PA
    Posts
    1,153
    I put the same engine in a Max II, using the same 49" belt, HP2031 that I used in my Attex with the Vanguard.
  6. #6
    Join Date
    Jul 2009
    Location
    Cleveland,Oh.
    Posts
    1,589
    [QUOTE=ARGOJIM;1 If I am wrong and you are talking an 18hp single cylinder ( which I've never seen) it would be much like the Tomahawk with the Tecumseh and should be fine.[/QUOTE]
    Jim,that's what I originally thought with the "L block" mention,then just assumed it's an opposed by the hp. Yeah,a single should fit real easy.
  7. #7
    Join Date
    Jun 2012
    Location
    north of Reno Nv.
    Posts
    27
    Thanks everyone, It Is a two cyl. as soon as I pick it up I will add some photos. from what I can tell the L refers to the cylinders are horizontal but at a offset. I was able to find some info online. the model # is 422437.
    I think the l block will make it longer but not wider than a vanguard ? Ill let you know what I find out. I am picking it up on Saturday.
  8. #8
    Join Date
    Jun 2012
    Location
    Western MD
    Posts
    136
    I put a 18hp opposed B&S in my Attex as well. It will fit but you would probably have to modify the engine cover (I didn't use the engine cover on mine). Just watch the chains, I made my engine mount without the chains installed and ran into some problems there. Its a good engine some of the hustler models came with them, the only thing is some of them are getting up there in age and certain parts can be hard to find. But if someone is giving it to you I say go for it. Also you will have to get a new primary clutch and probably put a different spring in the driven clutch. I took mine out, and its awaiting a V twin Kawasaki as soon as I get it running.
    Courage Invites Critics
  9. #9
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Many of the opposed engines came with a small charging system so a mounted alternator may be needed depending on that.
  10. #10
    Join Date
    Jul 2009
    Location
    Cleveland,Oh.
    Posts
    1,589
    Mine had the front drive option with this sheave.
+ Reply to Thread
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
