Re assembling
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Re assembling
  1. #1
    Re assembling
    How are you guys attaching the body top to the tub?
    Dave
  2. #2
    Join Date
    Dec 2007
    Location
    amesbury.ma.
    Posts
    227
    Hi Dave, Early attex's used staples but I replaced mine with rivets and backing washers. Some machines use carriage bolts. Max 2s use a bolt threaded up through a flat spring steel doohickey and had a large wing nut on top. Take your pick and good luck. Later Mike
  3. #3
    Join Date
    Dec 2012
    Location
    Youngstown, Ohio
    Posts
    1,003
    I use flat self tapping Phillips head screws and then cut the end off so they don't stick out. The key is to drill a pilot hole first or you will crack the body. Works great for me because I can take it back off with no extra work.
  4. #4
    Thanks for the information. I assume your not using any adhesive and is the black edging stuff still available? One more thing, I'm looking for the rubber mounts for the headlights.
    Dave
  5. #5
    Join Date
    May 2009
    Location
    Meadville, Pa
    Posts
    3,286
    Where are you located. The races are held in Ashtabula Ohio and there is a swap meet during the event. I bet all that stuff could be found there.
  6. #6
    Join Date
    Sep 2009
    Location
    In Michigan out annoying the neighbors in something that has a motor in it!
    Posts
    484
    I have a body band molding off a Superchief that is available.
    The trouble with retirement is.... I never get a day off !!!!
  7. #7
    It's in good condition. What's the cost?
    Dave
  8. #8
    Join Date
    Jun 2012
    Location
    Western MD
    Posts
    136
    I used abs goo and the bolts that hold the body band on.
    http://www.6x6world.com/forums/conte...on-bumper.html
    Courage Invites Critics
  9. #9
    Join Date
    Dec 2007
    Location
    amesbury.ma.
    Posts
    227
    Hi Lantz, The only drawback to that is you'll never get it apart again. I'd just buy a foam gasket like they use on pickup caps. Later Mike
  10. #10
    Join Date
    Jun 2012
    Location
    Western MD
    Posts
    136
    From the factory mine was held together with ABS goo and staples. If I ever wanted to take it apart again I would take it apart like I did in the first place. But I have no intrest in taking it back apart.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
