how is the best way to repair holes in the tub thinking of fiberglass any idea`s
I'm thinking fiberglass is (almost) the worst thing to use....
First find out if your tub is made of Poly (HDPE) or ABS. How big is the hole and where is it located?
i think hdpe the hole is in bottom of tub small about 3/4'' oval where chain rub thought
You need some scrap abs and some acetone to make goo with. Mix the two and let them sit for a few days making sure to give a good stir every once on a while. You want a thick pudding mixture. Clean your damaged area with acetone several times the day before and of your repair. Give one more acetone cleaning and then poor/smear your patch on. Let it cure for at least a week, and you will be good to go. Lego's are abs if you can't find a scrap piece of body. Do not use any other material than abs goo/fiberglass mat soaked in abs goo to fill the hole. Overtime fiberglass or any non abs material will delaminates from the abs. Even subtle changes in temperature will cause the different materials to expand and contract at different rates resulting in cracking and separation.
what it is the abs do the same thing with it also . thanks for your time this is going to help alot
Lyle
this one has six #50 chains it says st400 on it you guys will have to help i don`t know anything about them
i did get the 440 mounted on the frame and running ajusted chains patching body then going to pull axles and drop frame in
not sure if i`m keeping this thing or not i want to get it on the road then see where we are @
