5x6
+ Reply to Thread
Results 1 to 3 of 3
Thread: 5x6
  1. #1
    Join Date
    Sep 2013
    Location
    Caldwell, Idaho
    Posts
    1,174
    5x6
    My Attex has been hard turning right for the last two runs in the yard and finally got a little time to try and fugure it out. The weld on the right front sprocket broke, so it was a 5x6 .
    Easy fix, these machine are allot of fun.
    Is this under warranty??
  2. #2
    Join Date
    Jun 2007
    Location
    Buffalo, NY area
    Posts
    2,968
    You know, for as little wear as it shows (for a 45 year old sprocket) it SHOULD be under warranty. I've broken a few sprocket tubes over the years on the Attexes, and it seems like most of the time it's a nice, clean shear like yours shows. On two occasions, I sheared a primary sprocket (first the left, then the right) on the Attex 8x8. JP towed me up a hill out of the creek with his Max II each time. When the primary goes, she doesn't "turn hard", she don't turn.
    You can add a gusset or two between the tube and the sprocket to help with the problem. It usually helps out a lot. Something along these lines. This is what happens when 'Race doesn't want things to break any longer.
  3. #3
    Join Date
    Sep 2013
    Location
    Caldwell, Idaho
    Posts
    1,174
    WOW that is mega beefy Mike.
    I will keep that in mind.
    Mine looks like just a lack of penatration on the tube. I will refrain myself from any dirty jokes that are coming to mind at the moment.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
