Jeff- just under 25' of chain will do it. A 50' roll will do two Attex machines with about 6" left over.
Jim- The frames from the ST and Colt models aren't as rounded on the bottom corners of the front and back, so they're a tight fit in a newer body, but they will fit. If you try to mix upper and lower bodies from the ST/Colt models and newer ones, they contours don't match up, but they'll go together with a little coaxing.
