Attex 295 Wild Wolf no spark
+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
Thread: Attex 295 Wild Wolf no spark
  1. #11
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    Well I have replaced the points and have very good spark. Also rebuilt top end. Now I need a procedure to set the timing. Still won't start but get an occasional pop on starting fluid. Gonna tack apart carb and clean it. Any other advice?
  2. #12
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Quote Originally Posted by 507rzr View Post
    Try YouTube for a timing procedure or maybe look in the manuals section on here for attex and it may be in there also.
    Good luck and keep us posted
    Thanks
    http://www.6x6world.com/images/jlo-t...-manual-09.jpg
  3. #13
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    Rebuilt top end and replaced points. Have tried setting the timing in multiple different positions. Had the carb off and cleaned twice. Wont run on ether either. Still cant get it to run. Any suggestions on what to do next? Getting pretty aggravating.
  4. #14
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    A simple yet possibly overlooked issue. Is the starter turning in the correct direction?
  5. #15
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    No clue I guess. Engine spins counterclockwise if looking t it from pulley side
  6. #16
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Won't even pop off if ya put some gas in cylinder??
  7. #17
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    Didn't try gas. Will tomorrow. Tried spray in carb. It has popped 3 times on 3 different battery charges.
  8. #18
    Join Date
    Dec 2012
    Location
    Youngstown, Ohio
    Posts
    1,003
    Quote Originally Posted by ARGOJIM View Post
    Spent almost two days once figuring that one out. Been there done that!
  9. #19
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    Quote Originally Posted by smudvapor View Post
    So what way should it be Turning?
  10. #20
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Pull the recoil and watch rotation.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
