Attex 295 Wild Wolf no spark
+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 34
Thread: Attex 295 Wild Wolf no spark
  1. #21
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    Well I poured some fuel in spark plugs hole. It tried to run. Good news ! So I guess I have a problem with the carb. It's getting fuel to it just not delivering it to the cylinder.
  2. #22
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Quote Originally Posted by 507rzr View Post
    Is this a mikuni or a walbro or tillotson pump carb?
  3. #23
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    It's a mikuni with a separate vacuum operated pump
  4. #24
    Join Date
    Dec 2012
    Location
    Youngstown, Ohio
    Posts
    1,003
    Do you have any way to prime the carb? You may not have a problem, you might just have no fuel in the carb. I would try putting gas in spark plug hole a couple more times. When it tries to run the pump should pull enough gas to get it started. If you don't have a primer for the fuel pump I would put one in or you will have the same problem over and over again.
  5. #25
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    I had a few extra minutes over the weekend. Kept trying the fuel in the plug hole thing. Its very close to running but it dies when i let off the key from the start position. I had to replace the key switch when i first got it. May have wired it wrong or im just not getting fuel in engine yet. I did partially shear a flywheel key in the process, that leads me to believe that my timing is off. Hopefully i am finally on the right track.
  6. #26
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    You just hit on 2 big things - sheared key and erroneous wiring. Get that straightened out she might purr like a kitten!
  7. #27
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    Well still no luck. It almost runs during crank but not quite. Getting fuel to carb but not sure it's getting in the engine. Any suggestions?
  8. #28
    Join Date
    Jan 2014
    Location
    clifton IL
    Posts
    812
    Float level could be wrong and not letting fuel in thru the needle and seat? Jets plugged? Will start if you put gas in cylinder?
  9. #29
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    Jets are not plugged. It doesn't run with gas in cylinder but almost. Makes some smoke and heat during crank. I will check float level next.
  10. #30
    Join Date
    Jun 2017
    Location
    Robinson, IL
    Posts
    72
    Adjusted float and now fuel runs out exhaust. Guess carb needs to come off again to lean it out. I really didn't think I moved it that much though. Must be a very finicky engine.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
